Out Of Band Management ??
In Aruba technologies can we have an out of band management network.
Or
Out of Band management VLAN
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Out Of Band Management ??
There is an OOB management port on the S3500 and S2500 Mobility Access Switches, however the 7200 series controllers do not have a traditional OOB management port. We use the 10G uplinks for data and use one of the gigabit ports as an OOB management port. We just picked a random vlan (999) to use and gave the IP interface an address in our layer 2 dark network.
Tim
Tim Cappalli | Aruba Security
Here is the controller matrix :
http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
Thank you
Victor Fabian
Lead Mobility Architect @WEI
