Outdoor Access Point 375 power over ethernet
Hi Dears,
Hope you guys are doing good.
We are deploying Aruba outdoor Access Points Model number(JZ177A) 375 which has 2 ports(1 Copper & 1 SFP), we are planning to connect access point on optical fiber keeping in mind distance limitation of copper above 100 meters.
Vertical pole does not have feasibility for power source hence we are using POE+ injector to power on the access point and data over fiber optics.
Will it work, has anyone done that in past.
Hardik.
Re: Outdoor Access Point 375 power over ethernet
It will work fine to power with POE on the ENET and data connect on the fiber, just make sure the wired/POE is not providing DHCP to the AP.
Jerrod Howard
