Moderator
Outdoor Mesh and Coverage Planning Tool
Learn how to build mesh links and outdoor coverage models using the Aruba Outdoor Planning tool. Outdoor Planning tool is available for free with simple one-time signup at http://outdoorplanner.arubanetworks.com
(view in My Videos)
Re: Outdoor Mesh and Coverage Planning Tool
[ Edited ]
Have there been any changes to the Planning Tool recently?  The signal strength on some of my recent configurations for a property are showing significantly stronger.  Where I was getting an estimation of only 5mb downstream now i'm getting as much as 15mb and my coverage area has also grown.
MVP
There are a number of assumptions that go into the modeling results within the outdoor planner. I would need to see your KMZ output that you are comparing with your real-world performance to know for sure. More than likely though, you used a higher design margin and your environment isn't as bad as the margin chose, or your client devices that are using to measure your actual have better Rx gains (atennas, better radio sensitivity, etc) and/or have higher output radios than the standard assumptions in the default client devices.
In general though, the outdoor planner standards (unless modified during the generation) take a very coverage-conservative take on the modeling. It requires very specific information from the user to fine tune things like design margin and client device type. Hope that makes sense.
Jerrod Howard
Sr. Techical Marketing Engineer
