Outdoor WLAN Mesh with Video
[ Edited ]
am trying to create an out-door wi-fi network with mesh routers for over ten (10) thousand active users in a community to view on demand videos and live streaming, which aruba out-door mesh routers do you, advice me to use.
Moderator
Re: Outdoor WLAN Mesh with Video
10 thousands is a big number.
For Video-On-Demand on such scale, you probably need to run IP Multicast over Wireless to make the solution scalable.
Aruba AirMesh outdoor routers support IP Multicast routing protocol PIM-SM inside the mesh and IGMP on the client side.
But for 10 thousands concurrent VoD sessions, you will need a lot of mesh nodes.
Best,
Xu
