Occasional Contributor I
PAPI_Send: sendto BLE Relay Controller failed
Does anyone seen anything like this in controller logs:
Feb 17 16:11:59  syslogdwrap[1710]: PAPI_Send: sendto BLE Relay Controller failed: No such file or directory Message Code 1005 Sequence Num is 12457
Feb 17 16:11:59  syslogdwrap[1710]: PAPI_Send: sendto BLE Relay Controller failed: No such file or directory Message Code 1005 Sequence Num is 12458
I could not find any explanation to this. The controller is 3200 and software is 6.4.3.3 (build 50954)
Good guesses are welcome :)
br.
Antti
Re: PAPI_Send: sendto BLE Relay Controller failed
BLE management is only supported on 7-series controllers.
Tim Cappalli | Aruba Security
Hi Tim,
Thanks for your reply.
Actually I would like to know why I´m seeing that kind of logs in a controller?
What I have to do to not have those? I tried "no logging level" command but that does not helpped.
those log keep pushing on every 6 seconds and that is annoying :)
br.
Antti
Fantti,
We have opened a bug for this. I will let you know when it is fixed.  It will require a code upgrade to your controller, however.
Hi Colin,
Ok, let me know :)
I will start the upgrade project for this controller.
Br.
Antti
I recently upgraded to AOS6.4.3.6 and am now seeing these BLE Relay Controller Failed messages in my syslogs.   I do not have any 7 series conrollers on my network.
Is there a way I can disable the BLE management to stop the messages?
Nothing that will stop the message.  We will post here when it is fixed.
Thanks for the quick reply!  I'll keep an eye out for the fix.
What controller platform and what version of code are you running?
We are running AOS6.4.3.6
Controllers:
Model | End of Support | Last Supported OS
3200XM   | 01-Aug-21 | 6.4.x
6000-400 | 31-Oct-19  | 6.4.x
M3mk1-S | 31-Oct-19  | 6.4.x
