MVP
PCI Compliance questions
Hello I got a client which is asking me some thigns for some PCI compliance
1-Which operating system is based the ArubaOS? ( I guess is linux??)
2-We have to provide an evidence  of which  algorithm it use to stororage the local robust password(where can i find this?)
Cheers
Carlos
Alternetworks Corp
MVP
Re: PCI Compliance questions
For all intents and purposes, AOS is a customized Aruba-built OS. What it was based on is not really relevant anymore as it's been modified byond the point of being related to its origin. Password encryption per Aruba CTO is 3DES-CBC.
Jerrod Howard
Sr. Techical Marketing Engineer
MVP
Thank you Jerrod!
Alternetworks Corp
MVP
which is the longitude of the password encryptation method.. i saw you said 3DES but its 1024? 2048?  the key size
The auditor is asking that as well...
Cheers
Carlos
Alternetworks Corp
MVP
Anyone?
Alternetworks Corp
