PEF
I'm sure this is an easy question, but how do you see firewall rule hits and traffic being dropped by the firewall in the controller?
Thank you,
Re: PEF
You can see traffic being denied by running:
show datapath session table | include D
Or for a specific IP:
show datapath session table 1.2.3.4 | include D
Tim Cappalli | Aruba Security
Aruba
Re: PEF
At a higher level, you can also see what Rule and Role hits are being hit from the WebUI.  It won't give you granular details, but can help to see what protocol...in what policy....in what role is being denied.
Monitoring --> Firewall Hits (under Controller on left)
ACCX | ACDX | ACMX
Re: PEF
show acl hits
 is another useful one to use in conjunction with the others suggested.
ACCP, ACCX #817, ACMP, ACMX #294
