PEFNG Questions
Hello all.  I have a couple of  weird questions about PEFNG and some issues I have ran into.
First of all, right now I do not have the PEFNG license installed on our 3200 controller.  After we upgraded to Aruba OS 5, we had issues with DHCP not working correctly to our tunneled access points, so we ditched PEFNG.  We are now running 6.2.13 I believe.  Anyway, I am needing to throttle a certain SSID, but from what I have seen you can't do it without the PEFNG license installed.  So, I installed it the other night, DHCP worked fine, but now I get a web page that pops up that there was an authentication error and you cannot continue.  This happens on any device I try to connect to them.  We are not using any type of authentication, only the SSID passwords.  Any ideas?
Re: PEFNG Questions
Do you have a captive portal configured for this SSID?
What ACLs are in your user role?
Tim Cappalli | Aruba Security
Aruba
Re: PEFNG Questions
When you come from a non-PEFNG install to one that has PEFNG installed, you change the nature of roles and access policies.   The role that was in place before was probably sufficient for your use, but now that you have PEFNG installed, it is likely trying to redirect you to a Captive Portal page.
For example, the initial role of a AAA profile without PEFNG is "logon".   This role when PEFNG installed is configured for Captive Portal.
Run show user to see what role the users are in
Run show rights <name-of-role> to see what policies are applied to the user now
If you want to allow the users full access (may be recommended until you determine how you want to use the roles/policies):
config t
aaa profile <name-of-AAA-profile>
initial-role authenticated
wr memory
AMFX | ACCX | ACDX | ACMX
Re: PEFNG Questions
So, you are saying that where it says initial role logon here will change to captive portal when I install the PEFNG license?
Re: PEFNG Questions
Where would I check to see if an SSID has captive portal turned on?  Even though we have had this Aruba system a few years, I still am not sure where some things are, and using SSH is even worse since I am not sure on commands.
Re: PEFNG Questions
What type of authentication are you using on the SSID?
What is your initial role in the AAA profile?
Aruba
Re: PEFNG Questions
The AAA profile you showed has logon as the initial role.  You mentioned on PSK authentication, so this is the role the users are likely getting assigned.  This logon role has captiveportal policies assigned, but typically does not have a default captive portal profile assigned.    The role itself will not change to "captive portal".    If you don't want any of this behavior, change your default role:
config t
aaa profile Greenbush-aaa-prof
By the way, was that screenshot before the PEFNG loaded?   If that is how it looks now, have you rebooted since you installed the PEFNG license?
Re: PEFNG Questions
I think the role is above in the jpeg I attached.  Right now all three SSID's are open with no password.  But I am wanting to add a password to our main one, but throttle our open SSID.
Re: PEFNG Questions
That screenshot is now, but I have uninstalled the license again so clients could connect.
Aruba
Re: PEFNG Questions
OK.    After reapplying the license and rebooting, you can change the initial-role to something like "authenticated" which will give the users full access.   You can then work on setting up a new role to assign to the specific network with bandwidth restrictions as necessary.
clembo wrote:
config t
