PLACE A PHONE IN ITS VLAN WITH LLDP MED
Hello.
I am a beginner in configuring Aruba controllers. I have simple configurations.
I have to configure an Aruba controller 7010 and I want to make a rule so when I connect a computer to a wired port it has to be in VLAN 1, but when it is an IP Phone, it has to be placed in VLAN 20. I have configured such a rule in a Cisco switch, but I cannot achieve the same result with the Aruba controller 7010. I am using LLDP MED.
I have configured the next commands:
configure terminal
vlan 20
ap lldp med-network-policy-profile Voice20
application-type voice
tagged
l2-priority 7
vlan 20
dscp 46
ap lldp profile P_Voice20
lldp-med-network-policy-profile Voice20
ap wired-port-profile WP_Voice20
lldp-profile P_Voice20
interface gigabitethernet 0/0/10
lldp receive
lldp transmit
lldp med
exit
This is the configuration I have found in many sites, but the IP Phone does not place in VLAN 20.
I have some doubts:
  1. How does the controller know the profile has to be assigned to a specific port?
  2. Does it mind whether the port is trusted or untrusted?
  3. The main question: Why does not it work? Can anyone help me?
The AOS version is 6.5.0.0.
The IP Phone is connected to port 0/0/10
(Aruba7010) #show lldp neighbor interface gigabitethernet 0/0/10 detail
Interface: GE0/0/10, Number of neighbors: 1
Chassis id: 192.168.92.50
Interface description: WAN PORT, ID: 00:15:65:46:13:61
Device MAC: 00:15:65:46:13:61
Last Update: Mon Aug  6 16:55:53 2018
Time to live: 180, Expires in: 140 Secs
System capabilities : Bridge, Router, Phone
Enabled capabilities: Bridge, Phone
System name: IPPHONE
System description:
IP Phone
Auto negotiation: Supported, Enabled
Autoneg capability:
  10Base-T, HD: yes, FD: yes
  100Base-T, HD: yes, FD: yes
Media attached unit type: 100BaseTXHD - 2 pair category 5 UTP, half duplex mode
(15)
LLDP-MED:
Device Type:  Communication Device Endpoint (Class III)
Capability:   LLDP-MED capabilities, Network policy, Extended power via MDI/PD,
Inventory
LLDP-MED Network Policy for: AppType: 1, Defined: no
  Descr:        Voice
  Layer 2 Priority: 0
  DSCP Value:   0
Extended Power-over-Ethernet:
  Power Type & Source: PD Device
  Power Source: PSE
  Power Priority: high
  Power Value:  4000
Inventory:
  Hardware Revision: 5.0.0.61
  Software Revision: 7.70.0.140
  Firmware Revision: 7.70.0.140
  Serial Number: 01565461361
  Manufacturer: Yealink
  Model:        SIP-T22P
In the previous show command I have seen that LLDP-MED Network Policy is not defined, and the Layer 2 Priority and DSCP values are 0. I have seen other samples that respond that the LLDP-MED Network Policy is defined, and the Layer 2 Priority and DSCP values are the ones configured previously.
Thanks for your help.
Alejandro
