The WS-5004 does not have any licensed POE ports. Either it is a POE module, or it is not.
EDIT: To be clear, the only controllers with licensed POE were the 600 series controllers. If you have a module that has POE, by default it should be on. There were no licensed POE parts on the WS-5004.
