Contributor I
POE on Cisco 3750 - Possible Suggestions?
Hey there
 I have an Aruba 225 AP and trying to do a port-channel for this device. The Cisco 3750 does not have poe+ in order to run 30w of power (the limit is 15w). Any suggestions to get both links to work? besides replacing the switches in that network closet. Thanks :)
Occasional Contributor I
Re: POE on Cisco 3750 - Possible Suggestions?
run a "show power inline"
Contributor II
You should be able to use a PoE injector on the ENET 0 port of the AP. Only one port provides power to the AP at a time. Make sure the PoE injector is 802.3at capable.
