PPPoE Issues and Limitations
Greetings!!!
Facing with PPPoE problem on my Aruba 620 controller and try to find some answer in here.
There was some discussion of the same problem but decision was not found:
http://community.arubanetworks.com/t5/Wireless-Access/PPPoE-connection-error-on-controller-650/m-p/268989/highlight/true#M61282
While trying to find some answer i've run into such info:
In the ArubaOS 6.1.2.8 Release Notes.pdf table
Table 28: PPPoE Issues and Limitations
Was mentioned a bug Bug ID: 64254
In some cases, an 620 controller might not send LCP echo responses resulting in an interruption of PPPoE connections. Workaround: None.
Further looking for reports about this bug didn't give any result.
Do anyone knows something about this bug and how to deal with it?
Re: PPPoE Issues and Limitations
This is closed as user config error.
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
