Contributor I
PPPoE problem
Hi Forum.
I have aruba 200 controller. Having 2 ports 1(WAN Port) is configured for PPPoE dialing while 2nd (LAN) has VLAN . I configured PPPoE username and password but when i connected my pc to LAN Port i cannot browse the internet. Plz help me. there is a MAC authentication with PPPoE Dialing, i give Controller's MAC for authentication.
Reagrds,
faisal
Re: PPPoE problem
Does the WAN interface VLAN get an ip address?  Do you have PPOE configured on the controller, or on the PC?
Contributor I
Re: PPPoE problem
Dear,
Thanks for your reply.I configured PPPoE Dialing on Controller not on PC, after wait of 10 minutes it worked.
Faisal
