PRTG SNMP Monitoring -Aruba 7205 controller and AP 305
Hi all,
I have deployed Aruba 7205 controller with AP 305 and i have enabled SNMP at the controller in order to monitor the AP up/down status. I am using PRTG monitoring tool to monitor it. However, it is not working.
Is it i need to manually input the Controller MIB file into the PRTG in order to monitor it?May i know which MIB oid i can use for this because there are alot of oid inside the MIB file.
thanks!
KL
Re: PRTG SNMP Monitoring -Aruba 7205 controller and AP 305
Hi ,
If you have already uploaded complete AOS MIB file to the PRTG tool but still you are not seeing the APs status updates then,please open AOS TAC ticket.
http://www.arubanetworks.com/support-services/contact-support/
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
