Regular Contributor I
Palo Alto connection
I've just upgraded a customers pair of 7200 controllers to and the active PAN profile shows the Palo Alto "Down" with nothing sent. A packet capture on the controller showed a failure in the TLSv1 exchange with the certificate - "unknown CA" when I rolled back the code to an earlier 6.4 version it started working again. Anyone any ideas what the issue might be?
Re: Palo Alto connection
Exactly which earlier 6.4 version did you upgrade from?
Colin Joseph
Aruba Customer Engineering
Occasional Contributor I
Hi, we are trying the same, but I can't get my PAN state to show as up? Our instants work perfectly, but our master/local setup not at all. I am pointing the Aruba pan integration to my MGT interface of the PAN. but no logs at all. I recken it has something to do with the certificate and you need to use the hostname instead of the ip address. any help would be appreciated.
