Patch Management
Can you share you policy for Patch Management in reference to an Aruba WLAN?
Super Contributor I
Re: Patch Management
I try to stay current on the latest GA release. I usually don't upgrade to the latest until at least the first major patch has been released, however once I've moved to it I do my best to get patches installed within a couple weeks after their release as long as there's nothing crazy in the release notes.
ACDX #419 | ACMP |
