Occasional Contributor I
Per port tunnel node to untrusted interface on Mobility controller
Hello!
Just a little question hopefully someone will know. I have a mobility controller on a perimiter network. The mobility controller has interfaces on a trusted and un-trusted network. From a site over a WAN connection I want to tunnel a wired connectiom back over the WAN and drop the traffic onto the un-trusted network. Previously I've had to use RAP's to do this. Does anyone know if this is possible?
The Aruba switches would be much better for this than a RAP.
Thank you
