Permanent Licensing?
Hello everyone
I have a doubt with the licensing of my controller 3400, what happens is that when I check my licensing capacity of ap's in the controller I appear the license with start date of January 31, 2016 and the expiration date says never.
Does this mean that I should never renew it?
Since when you buy the license only buy it for a year.
So should I renew the licensing or is it permanent?
Re: Permanent Licensing?
That's a permanent license.
Cheers
James
