Plan option in controller GUI
  • 1.  Plan option in controller GUI
    Posted Nov 03, 2012 04:08 AM
    Hi ,
    I am trying to use PLAN option in controller GUI.
    I have deployed 1 AP and applied FQLN . I have taken a floor plan 100 x 100 feet dimensions and uploaded to controller using plan tab. I have selected 10 users total and capacity based planning but controller suggests 2 AP and 2 AMs . but for this area 1 AP is sufficient.
    How to input dimensions for the floor plan ??
    I am able to see the deployed AP in floor plan but it is not showing coverage of that AP ?  controller suggested AP coverage is Visible
    Can anybody tell what output will be seen on controller >> will it show AP coverage, client location ???
  • 2.  RE: Plan option in controller GUI
    Posted Nov 03, 2012 06:41 PM
    the answers written in BOLD.
    a:
    use custom option - and enter the amount of ap's and am u deployed.
      a:
    Plan > New Building > Specification
    a: deply another AP as AIR-MONITOR or check your arm settings.
    a: for client location - u need at least 3 ap's.
    for ap coverage u need monitoring mode to work as well.
    Hope i gave u some idea on how to continue.
    have a good night.
    Me.
  • 3.  RE: Plan option in controller GUI
    Posted Nov 03, 2012 06:46 PM
    BTW:
    AirWave
    AIRWAVE+VISUALRF+3 AP'S (at least)
    u give to your client a great view on each client on is site. (logs,reports,monitoring and even visual movement on specific days and time)
    some deep info:
    http://www.arubanetworks.com/products/management-security-software-2/airwave/visualrf/
    *if u aren't sure - and would like to see the capabilities of this great software - u can install the AirWave on client site for demo limited by time*
  • 4.  RE: Plan option in controller GUI
    Posted Nov 04, 2012 01:26 AM
    hi thanks for reply...
    1. can we enter dimension for particular floor or only building dim option is there.
    2. for deployed ap i have selected Eirp 127 and it is broadcasting ssid with 22.5 radio power...but in Plan section , ap coverage is not visible..i
  • 5.  RE: Plan option in controller GUI
    Posted Nov 05, 2012 01:55 AM
    Hi pls see below image for reference ....
  • 6.  RE: Plan option in controller GUI
    Posted Nov 20, 2012 03:14 AM
    any idea why I am getting this kind of heat map ???
  • 7.  RE: Plan option in controller GUI
    Posted Nov 20, 2012 04:29 AM
    i might not fully understand the question, but you seem to have selected AP - Coverage with coverage rate of 10 SNR, so that is what you see.
    what did you expect to see? what do you see when you select layered SNR?
  • 8.  RE: Plan option in controller GUI
    Posted Nov 20, 2012 04:44 AM
    No matter what snr setting is , it displays same output ...
    I am expecting AP coverage and the total area is 100 sq. feet so it should show almost all area under wireless coverage ?
  • 9.  RE: Plan option in controller GUI
    Posted Nov 20, 2012 04:46 AM
    The access point displays a diamond around it, when it cannot see any other access points.  It needs other access points to measure how far the signal is propagating from it.
  • 10.  RE: Plan option in controller GUI
    Posted Nov 20, 2012 04:59 AM
    thanks Colin !
  • 11.  RE: Plan option in controller GUI
    Posted Nov 25, 2012 06:10 AM
    one more question.... Can we monitor graphically clients connected to an AP on Controller > Plan section ??
  • 12.  RE: Plan option in controller GUI
  • 13.  RE: Plan option in controller GUI
    Posted Nov 25, 2012 07:49 AM
    If you have enough access points and/or airmonitors that will improve your chances.  You would need 3 access points or air monitors currently on the same channel as the client to be able to do this.
