Please Help RAP Deployment
Hello every one i have rap deployment the scenario is rap will communicate with 7200 controller through USB modem huawei E8231s using Controller public ip my questions are what is the configuration parameter for this USB modem (huawei E8231s)& what is configuration steps required to complete this deployment because i made search and found different steps for this scenario
Re: Please Help RAP Deployment
I'm not familiar with that specific Huawei device. From your picture, it appears the Huawei USB device can also provide an SSID and PSK for connecting?
That device might not work with the RAPs. I suggest contacting TAC for assistance.
Charlie Clemmer
Aruba Customer Engineering
