Occasional Contributor I
Please explain how channel bonding (i.e. 40MHz channel width) allows more throughput
I'm early in the WLAN learning curve.  I can understand how more complex modulation schemes allow more data throughput.  However I don't understand how going to wider channels allows more data throughput without changing the modulation.
Does more channel width allow for faster / more aggressive transitions between the modulation states?
Re: Please explain how channel bonding (i.e. 40MHz channel width) allows more throughput
Channel bonding combines the throughput of two channels.
More reading lead to an explanation.
https://en.wikipedia.org/wiki/Orthogonal_frequency-division_multiplexing
The thing I was missing was that the QAM modulation is applied to each subcarrier.  So doubling the channel width doubles the number of subcarriers, which doubles the data rate.
