Contributor I
Please help
OK so Ive been dropped in the role of administrering the wireless infrastructure and am waiting for some training in the aruba system. until then I need to figure out a few things any help would be much appreciated. I have multipe ssid's 1 with wpa2 enterprise auth and user roles that I got the hang of pretty good.
I have a ssid with WEP encryption and was wondering what user roles and policies are applied to that sside ? where do i look to see how this is linked ?
thanks all.
Re: Please help
Please check the aaa profile mapped to the the Virtual AP. the user should fall into initial role of the aaa profile for psk.
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
Contributor I
Re: Please help
The initial role is set to Authenticated? in the firewall policies -> User Roles -> authenticated policy has any any
does this mean the ssid is putting everyody on the authenticated  policy with any any  ?
Trusted Contributor I
Re: Please help
yes, if that is the setting that would happen.
easiest way to check is just to connect yourself and check what you end up in.
