Please tell me what is difference between AP-225 eth1 wired port and AP-205 eth1 standby
Please tell me what is difference between AP-225 eth1 wireport and AP-205 eth1 standby!
Re: Please tell me what is difference between AP-225 eth1 wired port and AP-205 eth1 standby
ap-205 does not have an eth1.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
An AP-205 does not have a second ethernet interface.
Tim Cappalli | Aruba Security
Yes this is true AP-205 has only one eth port while AP-225 has 2 ports eth-0 and eth-1. Please take a look of attached screen shot and guide me the difference of Wired port and Standby port.  Ap-205 is coming with eth-1 stand by and AP-135 OR AP225i is coming with eth-1 wired port.
Wired port means it is configured for user access (wired ap profile).
I have 205H, it has Eth1 port.
Is there any difference between 205 and 205H ? or both are same ?
The 205H has two additional interfaces that can be used for client access.
Tim
There is a difference. For the specifics, please see the comparison page here http://www.arubanetworks.com/products/networking/access-points/
Colin Joseph
Aruba Customer Engineering
Thank you and you can see from screen shots all AP-205 are appearing with standby port. Kindly explain why is so?
The ports are not configured and link is down...
