Contributor II
PoE AP 224 and 225
Hi my question is about the PoE at on the new APs 220 when I use the two ports with LAG I will need to have:
1.-PoE 802.3at on both ports
2.-802.3at on one and the other with 802.3af
3.- Only one port with 802.3at.
All this is because I want to have all the functionality on the AP with no restrictions.
Thanks in advance.
Aruba
Re: PoE AP 224 and 225
Number 3.
Note that LAG is not supported in 6.3.0 software, but will be added in 6.3.1.
/Onno Harms
Aruba Networks
/Onno
Contributor II
Ok, Thank You so much.
Frequent Contributor II
Can either port run POE? Is the ap220 able to have 2 ports with POE for redundancy?
David Dipert
Aruba
Yes, either port can take POE (but the AP can not draw current from both ports simultaneously). This can be used for redundancy, but the AP will reboot when POE power is lost on one port.
/Onno
Thank you for clearing that up for me.
It would be nice if the ap wouldn't reboot if one of the links failed.
David Dipert
Can the AP225 use both ports in a LAG to create 2 gig link with ArubaOS 6.3.1  to be active/active or will it be active/passive?
