PoE on Ethernet cable, but data on SFP
Hello, I have a situation where I want to install a AP-375 with an SFP data uplink on a high pole. I can't get power up high with standard power adapter, so I am thinking of using a PoE injector at the bottom of the pole, and putting power (just power, no data) through an ethernet cable, up to the AP. Can that be done? Is the AP going to recognize the ethernet cable as just power, and have data on the optical wire, or is it going to get "confused".
