Contributor II
Point to Point Wireless Bridge
Looking to do a point to point wireless bridge and the wireless link will need to also carry multiple VLAN's.  First of all can Aruba AP's do that?
Initially I was looking at couple of Cisco AP's with directional or Yagi's, but I like the Aruba AP's too so need to get some idea.
Secondly I'm looking at IAP-274 with directional antenna 5314/2314 vs IAP-277.  Any one had any experience with either?  I'm leaning towards IAP-277 just because it does have integrated directional antennas and its 3x3:3.  I'm going approximately 600'.
Thanks for your help
Re: Point to Point Wireless Bridge
