Frequent Contributor I
Point to Point signal question
My question is really just trying to make sure i am understanding the information i have.  Here is the background:
i have a Point to Point mesh going about 60-80 feet accross the street.  It is using an AP92 on each side. The Client side has a switch connected to the AP providing network to the building which consists of a few offices with 4-5 workstations and a few IP phones(hardwired).  We are running software version 6.1.3.0
Users have been complaining recently of poor network performance and had a few issues with their phones loosing connection.  Introubleshooting this i went the the VRD for a point to point and made sure i had good settings for things. I am now looking to see if we are having a signal problems.  Airwave reports the following, hopefully this is not formatted to poorly and it will help)
AP Name Ascending Device Address Link Time Duration Link Type Local Radio Index Remote Radio Index SNR Signal RSSI Transmit Rate Receive Rate
209 Portal - NE36400:24:6C:C7:C9:EA2/20/2012 9:37 AM135 days 23 hrs 5 minsUplink1127-85 dBm27184 bps
120 bps
The show sp arm rf-summary commands show this:
show ap arm rf-summary ap-name "209-Client - NE365"
Channel Summary
channel  retry  phy-err  mac-err  noise  cov-idx  intf_idx
161      5      0        4        93     12/0     25/0//0/0
1        0      0        0        0      0/0      0/0//0/0
48       0      0        0        0      0/0      0/0//0/0
165      0      0        0        0      0/0      0/0//0/0
6        0      0        0        0      0/0      0/0//0/0
7        0      0        0        0      0/0      0/0//0/0
149      0      0        0        0      0/0      0/0//0/0
11       0      0        0        0      0/0      0/0//0/0
36       0      0        0        0      0/0      0/0//0/0
153      0      0        0        0      0/0      0/0//0/0
40       0      0        0        0      0/0      0/0//0/0
157      0      0        0        0      0/0      0/0//0/0
44       0      0        0        0      0/0      0/0//0/0
HT Channel Summary
channel_pair  Pairwise_intf_index
1-5           0
7-11          0
149-153       0
36-40         0
157-161       25
44-48         0
Interface Name           :wifi0
Current ARM Assignment   :161/36
Covered channels a/g     :1/0
Free channels a/g        :8/5
ARM Edge State           :enable
Last check channel/pwr   :8d:21h:23m:59s/8d:21h:23m:59s
Last change channel/pwr  :8d:21h:23m:59s/8d:21h:23m:59s
Next Check channel/pwr   :0s/0s
It looks like the channel its on has alot of interference/noise.  Am i reading that right?  If that is the case why does ARM not switch it to a different channel to try and get less noise?
Aruba
Re: Point to Point signal question
What are your ARM profile settings and Radio profile settings for the APs involved in this link ?
An update to this.  I create a whole new profile from scratch for the mesh. I followed the VRD for a Point to Point Mesh for the whole thing.    I have been experimenting with 2 spare AP's and even when they are in the same room i cannot seem to get them to better signal strength then -65dbm.   ARM is disabled.  Here is the Radio profile settings for the A radio(g is disabled).  Let me know if there is anything else i can provide. Left is B/G and the right column is A
Radio enable                                                   Disabled        Enabled
Mode        ap-mode         ap-mode
High throughput enable (radio)                    Disabled        Enabled
Channel                                                            N/A             161-
Beacon Period                                                 100 msec        100 msec
Beacon Regulate                                             Disabled        Disabled
Transmit EIRP                                                  15 dBm          36 dBm
Advertise 802.11d and 802.11h Capabilities     Disabled        Disabled
TPC Power                                                        15 dBm          15 dBm
Spectrum load balancing                                Disabled        Disabled
Spectrum Load balancing mode                   channel         channel
Spectrum load balancing update interval (sec)  30 seconds      20 seconds
Spectrum load balancing threshold (%)          20 percent      20 percent
Advertized regulatory max EIRP                        0               0
Spectrum Load Balancing domain                   N/A             N/A
RX Sensitivity Tuning Based Channel Reuse      disable         disable
RX Sensitivity Threshold                                    0 -dBm          0 -dBm
Non 802.11 Interference Immunity                   Level-2         Level-2
Enable CSA                                                        Disabled        Disabled
CSA Count                                                           4               4
Management Frame Throttle interval             1 sec           1 sec
Management Frame Throttle Limit                20              20
ARM/WIDS Override                                          Disabled        Disabled
Protection for 802.11b Clients                         Enabled         N/A
Maximum Distance                                          0 meters        25 meters
This should be a relatively simple setup and should work.
Please attach a "show tech-support" from the controller.
What antenna type do you have on each side?
-cl
