Point-to-point setup with 2 MST200.
I have a MST200 on each side.
Configured the following:
Host Name
Mesh-ID
Management IP
Security Type
Security Key
Max Allowed Links.
I can see the links up for each AP,  just not able to pass any traffic.  They are plugged into an ALcatel switch on boths sided to a trunk port.
what am I missing on the AP side or dothe switch ports need a different config?
MVP
Re: Point-to-point setup with 2 MST200.
What is your ethernet configuration configured as? A sample would be:
interface gigabit-ethernet 0
 mode gateway
 switchport trunk allowed-vlan 100,150
 switchport trunk native vlan 100
interface vlan 100
 ip address 192.168.100.211/24
 mtu 1500
Jerrod Howard
Sr. Techical Marketing Engineer
mode none
switchport trunk allowed-vlan 1,3,7,202,302,620
switchport trunk native vlan 7
interface loopback 0
ip address from-mac
router-id
interface vlan 7
description data
ip address 10.2.2.30/16
mtu 1500
I have changed the mode to gateway,  should this only be set on the one side?
at each side the AP's are connected to an Alcatel-Lucent switch with the following ports vlans.
MS-IDF4-6450-> show vlan port 1/5
  vlan     type      status
     3    qtagged   forwarding
     7    default   forwarding
   202    qtagged   forwarding
   302    qtagged   forwarding
   620    qtagged   forwarding
