Frequent Contributor I
Polling Campus APs via ICMP
[ Edited ]
  • Hello, on Customer Side we will poll the APs via ICMP wether they are reachable or not. The got there IP Adress via DHCP. So while booting they are available from the local and remote Subnets. After connecting to the Controller, they are only available from the local Subnet. If we poll them from remote/different Subnets it seems, that the replay is send through the Tunnel (seen in logging of the connected Firewall connected on the Controller Port). Is this normal behavior  and is this changeable? So that we can monitor the APs from different Subnets via ICMP?
Best Regards
MVP
Re: Polling Campus APs via ICMP
Are they being run in CPSec mode or RAP mode?
Jerrod Howard
Sr. Techical Marketing Engineer
Hello, they run not as RAP, so the are Campus APs. CPsec is default and i use Release 6.1.0.7, so i mean it is enable.
Best Regards
