Pooled licensing model between two Aruba controllers
Is there documentation on how to set this up? I haven't been able to locate the setup for this in the user guide. We have two 3400 Controllers running 32 AP licenses each. What would we like to accomplish is combine the licenses into one pool so that in the event that a controller fails, all of our APs will be able to register.
I am new to these devices but it is my understanding this is possible with a memory and ArubaOS upgrade. Recently upgraded each Controller to 1 GB of RAM in preperation.
Thanks in advance.
Re: Pooled licensing model between two Aruba controllers
Nevermind, I see that is feature isn't on a GA release yet, just ED.
Contributor I
We have deployed it into a Master / Local / Local setup and it was as simple as one checkbox. Worked without problem.
Configuration > Network > Controller > Centralized Licenses > "Enable Centralized Licensing"
The master told the locals, and they all registered their licenses with master.
Contributor I
What happens if the master license server goes offline?  is there a "How to" somewhere to configure this feature?
Thanks!
You have 30 days to reconnect the disconnected "slave" controller to the master.  The 6.3 user guide has the details.
The license clients will remain licensed for 30 days. The 6.3 manual has a
pretty good config guide.
Tim Cappalli | Aruba Security
