Port Forwarding rules
  • 1.  Port Forwarding rules
    Posted Sep 09, 2012 09:03 AM
    I would like to know how to do port forwarding in Aruba, and could this be applied to CAP and RAP and if RAP is configured as split tunnel, is it possible to configure a port forwarding rule? if yes. how?.
    Thanks in advance,
  • 2.  RE: Port Forwarding rules
    Posted Sep 09, 2012 01:51 PM
    Port forwarding should only be configured in the form of a dst-nat ACL on the wired port of a controller that is a public interface.
    For example, if the wired physical port of a controller has a public address of 24.34.223.118 and you have an internal host (192.168.1.20) that needs to be reached on port 80, you would do the following;
    config t
    ip access-list session "port-forward"
    any host 24.34.223.118 any dst-nat ip 192.168.1.20 80 queue low
    exit
    vlan 20
    interface vlan 20
    ip address 24.34.223.118 255.255.255.192
    exit
    interface gigabitethernet 2/0
    switchport mode access
    switchport access vlan 20
    ip access-group "port-forward" session
    exit
  • 3.  RE: Port Forwarding rules
    Posted Sep 09, 2012 08:28 PM
