Post iOS 11 upgrade web redirection is badly degraded
Post upgrade to iOS 11, this has been observed with many users that while connecting to Enterprise guest wireless network it takes around 2 mins for web redirection for web auth.
Can see in the captures taken on Cisco WLC (5508, ver 8.2.141) the redirection is being sent immediately to endpoint however web auth portal doesnt pops up automatically. On further debug, could see on couple of endpoints ( iphone 6 or 6s) tries to reach to www.apple.com 7 times before failing over  to captive.apple.com, Web redirection doesnt work until failover to captive.apple.com happens. Whereas at the same time other endpoints ( iphone 6, 6s,5s,5c) running with same version i.e iOS11 tries to reach captive.apple.com at the first instance and automatic web redirection works perfectly fine.
Please note it was working fine when all the users were running with iOS 10. And Endpoints always used to go to captive.apple.com
No changes are done on wireless infrastructure.
Componenets Used:
WLC - Cisco 5508 (ver 8.2.141)
Radius - CPPM (ver 6.6.7)
Note - Android users are not facing any such issue.
Is anybody else have gone through such issue or observation and can help if any resolution is found ?
Thanks in advance
Nitish
Re: Post iOS 11 upgrade web redirection is badly degraded
Please check to make sure that your Captive Portal Server Certificate is using Sha-2 certificates and your key size on that certificate is 2048 bits.  https://support.apple.com/en-in/HT207828
Thanks for the reply Colin, it has been already validated and in place.
Nitish
Do you have a case open with Cisco TAC?
Tim Cappalli | Aruba Security
