Power Injector Aruba IAP 103
Hello. Tell please what compatible adapters can be used? What it is possible to replace with JW627A PD-3501G-AC 15.4W 802.3af PoE 10/100/1000Base-T Ethernet Midspan Injector.
I can use these adapters, is written that they have a support 802.3 af
1). PoE Intellinet 524179
P.S I tried to find this adapter in distributors but haven't found.
Re: Power Injector Aruba IAP 103
2). Doesn't approach. I have found another on the website PoE Injector Tp-Link TL-PoE150S, likely we will compatible
Any 802.3af certified power injector should work fine for the 103.
Jerrod Howard
