Super Contributor I
Power for AP135
Since AP135 support both 802.3af and 802.3at standard, what is the advantage of using 802.3at standard since we are not going using the second Ethernet port?
Normal Guy
Re: Power for AP135
There are some lower end switching platforms that at some distances will not provide standard 802.3af power necessary to power the AP.  802.3at will eliminate this issue entirely.
Super Contributor I
Re: Power for AP135
Thanks Joseph
Normal Guy
