Powering outdoor AP's using solar.
I am looking to design a semi-portable solution to power outdoor AP's using solar.
While I am aware that there numerous options I am looking for user cases from people who have already done this with Aruba AP's in particular.
A search on the forum throws up a 3yr old post (http://community.arubanetworks.com/t5/Access-Points/Powering-APs-through-solar-panels/m-p/2480)  but I would like to hear if anyone has done this with the newer AP's.
Thanks.
Re: Powering outdoor AP's using solar.
I was curious on if you found any luck with the solar panels.  I am looking into deploying a few at my location as well.  Any recommendations or lessons learned?  The only vendor I can see from Aruba's list that supports this is Solis Energy.
http://www.arubanetworks.com/aruba-partners/ecosystem-partners/enclosures-power-and-accessories/#solisenergy
Anybody successfully depoly solar panels for their outdoor AP's?
