Pre-design testing for signal strength
I need to provide an active AP that can be temporary mounted on a wall of an apartment and activate a wireless network signal. The customer uses Aruba 215 APs. How to get the AP to produce a signal or how to take a signal reading? Can a Aruba AP just be powerd up and produce a readable signal and how do you read the signal? Or does it need a Aruba controller to produce signal?
Thank you.
Re: Pre-design testing for signal strength
You need a controller to configure the Site Survey AP.  When it is successfully configured, you don't need the controller anymore.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-a-pre-802-11n-AP-for-site-survey-testing/ta-p/176978
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Regular Contributor II
Or use a IAP
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
