Contributor I
Preprovisioning a RAP 109 with a 3400 controller
I am having an issue Preprovisioning a RAP 109 with a 3400 controller.  I have used the RAP Network guide and I am up to the stage of provisioning the RAP.  I have added the rap mac to rap whitelist however it does not connect to the controller.   When I look at the logs it states User BV0033925:24:de:c6:cd:65:6a was not found in the database. User BV0033925:24:de:c6:cd:65:6a Failed Authentication.
How do I get the RAP to provision, do I have to add the user, I can't imagine that I would have to do this for each rap. Of course this is my first rap deployment.
Re: Preprovisioning a RAP 109 with a 3400 controller
yes, you need to add it to the rap whitelist on the master controller.
Configuration > AP Installation > Whitelist > Remote AP and then add the RAP into that.
I assume you've already configured a nat pool for the RAPs?
ACCP, ACCX #817, ACMP, ACMX #294
Contributor I
I do have the rap in the whitelist with AP Group of Remote-AP-Group and have the ipsec address pool (called RAP), this is a subset of addresses 172.17.0.10- 20 on the same subnet as the controller 172.17.0.0/24 vlan 1
Not sure if this is helpful but just to give a summary of what I have:
Setup an Remote-AP-Group has a vap with vlan 17
The Internal DB has a user rapuser with ap-role
ap-role has vlan 1 with L2TP pool of RAP
However when I connect the rap to the controller directly it picks up 172.17.0.51, however the rap does not provision.  Really not sure what I am missing here.
Ideally what I want to do is have multiple rap's on different remote sites with different subnets for staff and again a different subnet for guests.
Make sure you are running the right minimum version of Code.
The RAP 100 series access points requires ArubaOS 6.2.0.0 and above:  http://www.arubanetworks.com/pdf/products/DS_RAP-100.pdf
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
The rap is running 6.2.0.0-3.2.0.4_38110
The 3400 controller needs to be running 6.2.0.0 and above.
Contributor I
Ok I have updated the controller to 6.2 however the rap doesn't provision.  Any tips?
Valued Contributor I
A RAP-109 is an InstantAP out of the box.  Have you gone into the IAP's Maintenance tab > Convert > then pointed the IAP to the controllers IP?  Once you do this the RAP-109 should set up a connection with the controller and get thin AP code and the config from the controller.
Contributor I
Unfortunately I got an error back trying this.
Response data is corrupted!
Request url part:
opcode=convert-ap&host=172.17.0.254&oper_id=E4F01794-0E0E-491D-B8F5-45E6E325E8C8&mode=remote
Request url part:
Is that when you try to do a convert from theGUI of the RAP109?
