Contributor II
Problem AP225
Hi
I´m deploying an AP225 and an AP135 together (same AP Group) on a controller 3400 (AOS 6.3.0.1).
All is ok for the AP135.
But the AP225 always goes to Monitor mode.
What could be happening here?
Thanks in advance.
Aruba
Re: Problem AP225
What's the configured country of operation?
/Onno
Contributor II
Re: Problem AP225
The controller is configured for Mexico.
Thanks.
Aruba
Re: Problem AP225
Mexico is not yet a supported country for the AP-225. As a matter of fact, the product has no regulatory certs for Mexico yet and should not have shipped there. Who's your sales contact at Aruba?
/Onno
Aruba
Re: Problem AP225
The behavior you see is expected. Once certs are available, a SW update will enable AP-225 operation in Mexico.
/Onno
Contributor II
Re: Problem AP225
This is only a test for our labs.
And then I should wait for the update.
Thank you.
Aruba
Re: Problem AP225
In a lab you could test after setting the country code to a supported one (US for example), but for a real deployment that would be illegal.
/Onno
Contributor II
Re: Problem AP225
Ok, then I will change the Country Code.
And thanks for the advice.
Regards.
Frequent Contributor II
Re: Problem AP225
What about now in 2014 with AOS 6.3.1.2AOS that is in production recommended by our Technical Support Engineer in Mexico)?.
I have a similar thing with an open case since some months ago and seems like a M3MK1 (6000 controller) module is hardware restricted.
