last person joined: 9 hours ago
Problem Appliance Controller Aruba
  • 1.  Problem Appliance Controller Aruba
    Posted Jul 30, 2014 11:53 AM
    Hi Team,
    My device is the ARUBA3200 US model, but my region is Rest of the World. I can fix this with an update?
  • 2.  RE: Problem Appliance Controller Aruba
    Posted Jul 30, 2014 11:55 AM
    No, you cannot. You need to order the correct domain.
  • 3.  RE: Problem Appliance Controller Aruba
    Posted Jul 30, 2014 11:59 AM
    You mean, change device  :(
  • 4.  RE: Problem Appliance Controller Aruba
    Posted Jul 30, 2014 01:22 PM
    Correct. The controllers are country specific and cannot be changed. Get with the partner you purchased it from if its new and get it switched for the proper device. If it's used and you just bought it I would still try to see if you can return it and get the proper device.
