Frequent Contributor I
Problem Getting a RAP3 to Function as Hybrid Spectrum Monitor
Question about the Hybrid Spectrum Monitors/Sensors. Currently, I have a 3400 series controller running 6.2.1.4. I created a new AP group and placed a number of RAP3 into the group. The RAP3s are up and servicing clients. But, I want to monitor spectrum where the RAPs exists.
So, I followed the steps in http://www.arubanetworks.com/wp-content/uploads/RFSpectrumWLANsAppNote_20120514.pdf and enabled 'Spectrum Monitoring' for the 802.11a Radio in a dedicated RAP Group under the RF Management section.
When I click on the Spectrum Analysis Tab and try to add the provisioned RAP3 to the dashboard, I get the error:
"There are no spectrum monitors configured. Please configure spectrum monitors from CLI or Configuration tab in WebUI. Please refer the documentation for more details."
Is it possible to use a RAP3 as a Hybrid Spectrum Monitor/Sensor on a 3400 Series Controller(6.2.1.4).
Anthony
Aruba
Re: Problem Getting a RAP3 to Function as Hybrid Spectrum Monitor
The RAP3 is a single radio (2.4GHz only), so enabling spectrum on the 802.11a radio will have no effect on it.
AMFX | ACCX | ACDX | ACMX
I'm not 100% certain but I don't believe you can use a RAP3 as a spectrum monitor, certain not mentioned on the product page (where if you check the 105's for example it is listed as a feature..)
http://www.arubanetworks.com/products/rap-3/
Maybe someone can confirm?
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Thanks for the reply and info.
When I checked the RAP3 Specs page, I pulled the following info:
Operating Modes
  • Wireless
    • 802.11b/g/n Mobility Controller-managed RAP
    • 802.11b/g/n Aruba Instant AP
    • 802.11b/g/n air monitor
    • Hybrid WLAN and air monitor
Anthony
Aruba
Yes, but see my post above.  You made the change to the 802.11a radio profile.  The RAP-3 does not have an 802.11a radio; only 802.11b/g.    Try changing the 802.11g radio profile.
Ahhhh! You're right. I'll update the correct radio profile and try.
Anthony
Okay. I removed the settings from 802.11a radio and applied to 802.11g radio.
I saved applied changes and saved the configs. After applying changes to the controller, I waited a couple of minutes and then rebooted the RAP.
After reboot, I verified connectivity from the RAP. No issues connecting to internet.
When I log into the controller and try to add/connect to the RAP from the dashboard, I still get error:
Anthony
