Problem Mac Filtering Aruba controller 7205
Thanks in advice for your help.
I already configure all the stuff for this to work, but I’m missing something, for example is necessary the PEF license for this to work.
I just need that a SSID work with PSK+Mac Filtering.
Thanks a lot.
Re: Problem Mac Filtering Aruba controller 7205
Yes.
You need the PEF license to have a different role after mac authentication.
Colin Joseph
Aruba Customer Engineering
Thanks a lot for your quick answer, I know is a stupid question, it’s possible to activate that license in some way as demo or is necessary to buy it.
Or if you know a workaround to solve the issue without buying the license.
Sorry for my English.
Again thank you very much
If I implement clearpass I will need that license too?
It seems that I am wrong.  Check to see if you can execute these commands:
config t
aaa authentication mac mac-profile
 Not having the PEF license could significantly reduce your productivity, however.  You would be limited even if you add ClearPass..
Colin Joseph
