Hi All,
I thought I would play with the eval of ALE, so I have deployed it to our lab ESX host, but when I try change the password as required at first login i just get pushed back to the login.
I can log in again with the default root/admin credentials but get prompted to change the password but not re type it as i would expect and then get sent back to the login.
I have tried ALE-1.2.0.0-42792 & ALE-1.2.1.0-43065 but hit the same "issue" both with the ova and the iso
does anyone know if there is a known issue and there is a special way to sort the first login out (possibly booting into single user mode)
cheers
Andy
