Problem provison AP aruba
HI ,
This error appears when I try to put the AP provision ,
Error browser
"Not all IPSec parameters are set; please set the remaining parameters"
controller 3400
AP - 105
Re: Problem provison AP aruba
What AOS are you using ? This is a known bug and the workaround is to do it through CLI
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Super Contributor II
I remember seeing this but still managed it in the GUI. Try checking the radio button for PSK and the back to certificate - It might be a CAP your provisioning but doing this with one of the settings on the provisioning page worked for me.
cassio wrote:
HI ,
Error browser
controller 3400
AP - 105
Please supply:
- the version of ArubaOS
- a screenshot
