Contributor I
Problem witch split tunnel
Hi folks
I have a question and the question is the next, How the traffic leaving from AP when this is remote ap mode split tunnel, traffic from users is nat through  the IP of the  remote AP  ?.
Re: Problem witch split tunnel
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/For-the-Beginner-RAP-Split-Tunnel-configuration-v2/ta-p/79788
There is an any any any route source-nat rule that nats all user traffic out of the access point.
