Problem with AP-105 Checksum bad
I have and AP-105 that is registering a checksum bad.
I plugged it into so I could provision it and it never showed up on my list of ap's
so I hooked up a console cable to it and this is the output.  I have tried to purge the ap and that hasnt worked either.  All it does is what is shown in the putty output.  I let the unit just set their and just keeps saying checksum bad...
any help would be appericated
APBoot 1.2.4.4 (build 26618)
Built: 2011-01-07 at 13:42:04
Model: AP-10x
CPU: AR7161 revision: A2
Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
DRAM: 128 MB
POST1: passed
Copy: done
Flash: 16 MB
PCI: scanning bus 0 ...
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
Net: eth0
Radio: ar922x#0, ar922x#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 100 Mb/s full duplex
DHCP broadcast 1
invalid RARP header
DHCP broadcast 2
DHCP IP address: 170.117.132.49
DHCP subnet mask: 255.255.240.0
DHCP def gateway: 170.117.128.1
DHCP DNS server: 170.117.137.2
DHCP DNS domain: cmc-nh.org
ADP multicast 1
ADP broadcast 1
ADP multicast 2
invalid RARP header
ADP broadcast 2
checksum bad
ADP multicast 3
Retry count exceeded
DNS request 1 for aruba-master.cmc-nh.org to 170.117.137.2
T Using eth0 device
TFTP from server 170.117.137.162; our IP address is 170.117.132.49
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: invalid RARP header
T T T T T T T T invalid RARP header
T T
Retry count exceeded; starting again
checksum bad
checksum bad
checksum bad
invalid RARP header
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
checksum bad
Retired Employee
Re: Problem with AP-105 Checksum bad
Does this IP 170.117.137.162 belong to your controller?
It looks like the mips32.ari AP image that you are downloading from the TFTP server is corrupt and you would have to get a clean image.
HT
Yes the 170.117.137.162 belongs to the controller.   However I have been able to provision more access points after this one in questions.  We have 50 ap's I am provisioning and the AP in question is number 20 and I have already configured 12 more since then with no problem.
Retired Employee
snewell,
Can you try connecting the AP directly to the controller port ? If that is not possible then try changing the switch port to which the AP is connected to.
If the above two does not help then please open a case with support.
HT
Thanks HT I will have to call in and open a support ticket as I already have it plugged into a port on the controller to configure the aps.  that is where the message came from
Regular Contributor I
Hi there,
have some similar issue here, got some AP124 with old APboot 1.0.8.3  which came up with invalid_image 0xFFFFFFFF , i tested on some ArubaOS 6.1.3.4 controller, then i reminded that once there were issues with APs with older APboot, so i plugged into some controller with 5.0.4.7 and it came properly up and was able to be provisioned.
i dont get the clue again to put the latest Apboot on it so it comes also up on OS 6.x , anyone ?
i think its in the apboot menu with "upgrade" , but dont have the command , i will check again KB and guide and will post later i think i can fix this by myself
@cjoseph , give me 20minutes before you post ;-)
