Thank for your quick answer!
It is connecting to master server and after one minute restarting again.
See below
Hit <Enter> to stop autoboot: 0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
eth0 up: 1 Gb/s full duplex
DHCP broadcast 1
DHCP broadcast 2
DHCP broadcast 3
DHCP broadcast 4
DHCP broadcast 5
Retry count exceeded; starting again
DHCP broadcast 1
DHCP broadcast 2
DHCP broadcast 3
DHCP broadcast 4
DHCP broadcast 5
DHCP IP address: X.X.X.15
DHCP subnet mask: 255.255.255.0
DHCP def gateway: X.X.X.1
DHCP DNS server: X.X.2.25
DHCP DNS domain: XXXX.XXXXXXXXX.com
ADP multicast 1
Controller address: X.X.X.254
Using eth0 device
TFTP from server X.X.X.254; our IP address is X.X.X.15
Filename 'mips32.ari'.
Load address: 0x2000000
Loading: ######################T ###################################
done
Bytes transferred = 3700092 (38757c hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Automatic boot of image at addr 0x02000000 ...
ELF file is 32 bit
Loading .text @ 0x80e00000 (3631224 bytes)
Loading .data @ 0x81176880 (32 bytes)
Clearing .bss @ 0x811768a0 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing.................................
þ
Aruba Networks
ArubaOS Version 6.1.2.3 (build 30182 / label #30182)
Built by p4build@corsica on 2011-09-11 at 12:10:31 PDT (gcc version 4.3.3)
CPU Rev: aa
71x CPU
Flash variant: default
Cache parity protection disabled
Using 340.000 MHz high precision timer. cycles_per_jiffy=680000
Memory: 123008k/131072k available (1850k kernel code, 7928k reserved, 669k data, 2820k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=11788288
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ....................................................................................................................................................................................
AR7100 GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ar7100-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
AD7416 driver probing for devices on AR7100 I2C
.<6>lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Domain Name: arubanetworks.com
No panic info available
Testing TPM... TPM driver running in 3203 mode with 3204S
Passed
ag7100_mod: module license 'unspecified' taints kernel.
AG7100: Length per segment 512
AG7100: Max segments per packet 4
AG7100: Max tx descriptor count 400
AG7100: Max rx descriptor count 252
AG7100: fifo cfg 3 018001ff
AG7100CHH: Mac address for unit 0
AG7100CHH: d8:c7:c8:ce:8e:9f
ATHRF1: Port 0, Neg Success
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 0
AP xml model 39, num_radios 2 (jiffies 7371)
init_asap_mod: installation:0
radio 0: band 1 ant 0 max_ssid 8
radio 1: band 0 ant 0 max_ssid 8
setting bond0 as bridge child
setting gre0 as split child
Starting watchdog process...
Getting an IP address...
ag7100_ring_alloc Allocated 4800 at 0x87f42000
ag7100_ring_alloc Allocated 3024 at 0x804d8000
AG7100: cfg1 0xf cfg2 0x7014
ATHRF1: unit 0 phy addr 0 ATHRF1: reg0 3100
AG7100: unit 0: phy not up carrier 1
Writing 4
ADDRCONF(NETDEV_UP): bond0: link is not ready
AG7100: unit 0 phy is up...RGMii 1000Mbps full duplex
AG7100: pll reg 0x18050010: 0x110000 AG7100: cfg_1: 0x1ff0000
AG7100: cfg_2: 0x3ff
AG7100: cfg_3: 0x18001ff
AG7100: cfg_4: 0xffff
AG7100: cfg_5: 0xfffef
AG7100: done cfg2 0x7215 ifctl 0x0 miictrl 0x22
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
x.x.x.15 255.255.255.0 x.x.x.1
Running ADP...Done. Master is x.x.x.254
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_spectrum: Version 2.0.0
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
wifi0: Base BSSID XXXXXXX, 8 available BSSID(s)
bond0 address=XXXXXX
br0 address=XXXXXXX
wifi0: AP type AP-105, radio 0, max_bssids 8
wifi0: Atheros 9280: mem=0x10010000, irq=49 hw_base=0xb0010000
wifi1: Base BSSID XXXXXX, 8 available BSSID(s)
br0 address=XXXXX
wifi1: AP type AP-105, radio 1, max_bssids 8
wifi1: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
Starting FIPS KAT ... Completed FIPS KAT
AP rebooted Fri Dec 31 16:04:37 PST 1999; 'reboot' command executed with no reason given (called from ).
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
The system is going down NOW !!
Sending SIGTERM to all processes.
Please stand by while rebooting the system.
Restarting system.
