Problem with internet access from mobile phone connected to wifi
  • 1.  Problem with internet access from mobile phone connected to wifi
    Posted Mar 29, 2016 08:13 AM
    The APs and controller are connected to switch by wire, my laptop also is connected by wire to the same switch. APs and laptop have valid IP 4 address received from W-3200. When I connect my mobile phone to WiFi served by APs, I receive valid IP 4 address from the same pool.
    Now... I can successfuly using internet from my laptop, but not from mobile phone. When I wirte any internet web site into browser, I receive error message "Web authentication is disabled. Please contact the administrator for assistance". The internet address has changed, and now I have "https://securelogin.arubanetworks.com/auth/cp_disabled.html"
    What I have to set to have access to internet from devices connected to wifi?
    Mariusz
  • 2.  RE: Problem with internet access from mobile phone connected to wifi
    Posted Mar 29, 2016 08:18 AM
    I think the user is on logon role. Change the user-role to "authenticated" or a role that doesn't any any captive portal ACLs.
  • 3.  RE: Problem with internet access from mobile phone connected to wifi
    Posted Mar 29, 2016 08:38 AM
    Could you tell me. where to change this?
    Unfortunatelly, I'm just teaching aruba products and wireless networks, I chave only expirence with simple Wifi router for home use.
    I've created "myVirtualAP" profile under Advanced services -> All Profile Management -> Wireless LAN -> Virtual AP Profile"
    I've created "mySSID" profile under Advanced services -> All Profile Management -> Wireless LAN -> SSID Profile ", where I choose WPA2-PSK + AES, set password and choose "PSK Passphrase"
    I've created "MyGroup" under Configuration->AP Group. Here I assigng "myVirtualAP" and "mySSID", and under "AAA Profile" I choose "default-dot1x-psk". Here I see Initial role "logon", but the editbox is grayed and not accesible.
    May I ask you to help me with proper settings, to make internet available ftom mobile devices?
    Mariusz
  • 4.  RE: Problem with internet access from mobile phone connected to wifi
    Posted Mar 29, 2016 08:58 AM
    You would be able to change the initial role under - - Configuration - Authentication - AAA profiles.
    Rajaguru Vincent
    Sent from Nine
  • 5.  RE: Problem with internet access from mobile phone connected to wifi
    Posted Mar 29, 2016 09:16 AM
    Mariusz
