Occasional Contributor I
Problem with new AP
I'm new to Aruba. I have a Aruba 650 controller with five AP-105.
Four of my APs are working but I have problem with one. In the web interface, this AP has flag IL (inative and Unlicensed).
I added 4 AP licenses to my controller.
(AT-QUBC-WIFI1) #show ap license-usage
Total AP Licenses : 8
AP Licenses Used : 4
MUX Licenses Used : 0
Unused AP Licenses : 4
Licenses used for Campus AP's : 4
Available Campus AP's : 0
Licenses used for Remote AP's : 0
Available Remote AP's : 0
Total Ortronics AP Licenses : 0
Ortronics AP Licenses Used : 0
Total Indoor Mesh AP's Supported : 64
Indoor Mesh AP's Active : 0
Total Outdoor Mesh AP's supported : 64
Outdoor Mesh AP's Active : 0
Total PEF Licenses : 4
PEF Licenses Used : 4
Total 802.11n-120abg Licenses : 0
802.11n-120abg Licenses Used : 0
Total 802.11n-121abg Licenses : 0
802.11n-121abg Licenses Used : 0
Total 802.11n-124abg Licenses : 0
802.11n-124abg Licenses Used : 0
Total 802.11n-125abg Licenses : 0
802.11n-125abg Licenses Used : 0
I have a total of 8 AP licenses. As you can see, four of them are working and use license. Why does the last one doesn't come up ?
I'm new so I will give you all the details you need.
thank you !
Aruba
Re: Problem with new AP
AP #5 is not coming up as your PEF-NG licensing seems to be capped/limited to '4'.
my question may sound stupid but what is PEF-NG ?
Aruba
No question is stupid here... we are hear to help.
The PEF-NG is the Firewall license.
From your output we can see:
So... when you try to put AP # 5 on the system you really are out-of-licenses...  firewall licenses to be specific.
To remedy, you need to add Firewall (aka. PEF-NG) to 'match' the AP license count.
So in your case  8 - 4 = 4 more PEF-NG licenses. and then all will be well up to 8 APs.
thank you very much !
I will buy 4 more licenses for this !
Thanks again !
