Problem with provisioning RAP3WN
I've problems with provisioning RAP3WN.
In the Log of the Controller the following messages appear:
Aug 21 15:27:09localdb[1574]: <133019> <ERRS> |localdb| User BF0033077::00:0b:86:8e:17:d7 was not found in the database
Aug 21 15:27:09localdb[1574]: <133006> <ERRS> |localdb| User BF0033077::00:0b:86:8e:17:d7 Failed Authentication
Aug 21 15:27:09localdb[1574]: <133019> <ERRS> |localdb| User BF0032919::00:0b:86:8e:19:99 was not found in the database
Aug 21 15:27:09localdb[1574]: <133006> <ERRS> |localdb| User BF0032919::00:0b:86:8e:19:99 Failed Authentication
The Log of the RAP3 shows me the following:
Sending last fragment, size = 432
#RECV 80 bytes from 217.7.200.197[4500] (11.0)
(pid:2379)  time:2013-08-21 14:23:13
 spi={3c57f5d554b559d0 882ccbaa3aa4fb84} np=E{N}
 exchange=IKE_AUTH msgid=1 len=76
  I <--
   Notify: AUTHENTICATION_FAILED (ESP spi=4c035b00)
InNotify AP authentication failed
ike2_state.c (7737): errorCode = ERR_IKE_NOTIFY_PAYLOAD
IKE SA failed reason = ERR_IKE_XAUTH_FAILED, errorcode = -8952
send_sapd_error: error:45 debug_error:0
IKE_SA [v2 I] (id=0xa3f7a952) flags 0x41000015 failed reason = ERR_IKE_XAUTH_FAILED, errorcode = -8952
I think the problem is similar to this topic, but the answer isn't visible any more.
http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Rc-error-ike-xauth-authorization-failed/td-p/12112
What was the solution in this case? I'm wondering why the RAP is going to authenticate via username? Normaly it should connect via automatic certificate authentication?
Thank you,
Marco
Re: Problem with provisioning RAP3WN
Make sure you are running ArubaOS 6.2.x or higher on the controller before conversion.
