Problem with the Centralized Licensing
After activating the option of centralized licenses, I have some APs in local controllers with flags IL, and does not work provisioned again.
Any idea about this?
Frequent Contributor I
Re: Problem with the Centralized Licensing
For each of your controllers, what is the output of :
show license profile
show license server-table
show license-usage client
--Raf
Master Controller:
(MX-INT-P3-MDF-CTRLR-MASTER) #show license profile
License provisioning profile
Parameter Value
Centralized Licensing Enabled
(MX-INT-P3-MDF-CTRLR-MASTER) #show license-usage client
License Clients License Usage
Hostname IP Address AP Lic. Used PEF Lic. Used RF Protect Lic. Used xSec Lic. Used ACR Lic. Used Last update (secs. ago)
MX-INT-P3-MDF-CTRLR-MASTER 10.34.X.X 14 22 21 0 0 12
MX-TOL-UW-PB-MDF-CTRLR-LOCAL 10.34.X.X 0 2 2 0 0 13
GT-MIX-PB-MDF-CTRLR-LOCAL 10.34.X.X 5 5 5 0 0 7
MX-SAL-MDF-PB-CTRLR-LOCAL 10.34.X.X 6 6 6 0 0 26
MX-TOL-AI-PB-MDF-CTRLR-LOCAL 10.34.X.X 4 12 12 0 0 21
MX-ECA-P1-MDF1-CTRLR-LOCAL 10.34.X.X 4 4 4 0 0 25
MX-INT-P3-MDF-CTRLR-LOCAL 10.34.X.X 8 16 16 0 0 17
DO-SDQ-P4-MDF-CTRLR-LOCAL 10.149.X.X 1 0 0 0 0 0 22
MX-VAL-P1-MDF-CTRLR-LOCAL 10.34.X.X 1 1 1 0 0 19
GT-GUA-P15-MDF-CTRLR-LOCAL 10.148.X.X  8 8 8 0 0 2
MX-TL2-PB-MDF-CTRLR-LOCAL 10.34.X.X 2 2 2 0 0 16
Total AP Licenses Used :52
Total PEF Licenses Used :78
Total RF Protect Licenses Used :77
Total XSEC Licenses Used :0
Total ACR Licenses Used :0
Total no. of clients :11
(MX-INT-P3-MDF-CTRLR-MASTER) #show license server-table
License Server Table
Service Type Aggregate Lic. Used Lic. Remaining Lic.
Access Points 82 52 30
Next Generation Policy Enforcement Firewall Module 128 78 50
RF Protect 48 77 0
xSec Module 0 0 0
Advanced Cryptography 0 0 0
Parameter Value
LOCAL:
(DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license profile
Parameter Value
(DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license server-table
This command is applicable only on the license server
(DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license-usage client
Numbers seem to add up in "show license-usage client" & "show license server-table"
What are the actual # of installed licenses on each of your controllers?  show license
Make sure your local (clients) are pointing to the correct (server) :  show license debug
Are there any entiries in the logs pertaining to those APs that are not licensed?  Are those APs terminating on the same local controller, or different ones?
--Raf
--Raf
That is the output in the local controller
(MX-TOL-UW-PB-MDF-CTRLR-LOCAL) #show license
License Table
Key Installed Expires Flags Service Type
14:24:07
License Entries: 1
Flags: A - auto-generated; E - enabled; R - reboot required to activate
That is the output to the master controller
Do you know the way to disable this option and that each controller manage the licences locally?
Please edit this post and remove all your license keys .
Based on the outputs you shared , it looks like you may need  additional AP licenses
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor
Is possible do roll back to this action, in order to that each controller manage yours own licence again?
Hi Victor
I think that is not related with the license numbers, because before that I enable the centralized licensing all local controllers had the enough licenses number.
It's possible do the roll back, or there is a risk of losing some license?
